Original problem was sc 990 and Tech pulled and reconnected all wiring to the BCU board now has constant SC144.
I can go into service mode and print out data, so I don't think the BCU is bad.
Swapped out the VIB board and checked all ribbon connectors.
I did notice the lamp doesn't turn on when it powers up, but it will turn on in service mode.
Anyone else run into this?
I don't want to have to replace the SBU board if I can avoid it.
Thanks for any input.
