Ricoh 2015 sc 144
  • nmfaxman
    • 1702
    Ricoh 2015 sc 144
    Original problem was sc 990 and Tech pulled and reconnected all wiring to the BCU board now has constant SC144.
    I can go into service mode and print out data, so I don't think the BCU is bad.
    Swapped out the VIB board and checked all ribbon connectors.
    I did notice the lamp doesn't turn on when it powers up, but it will turn on in service mode.
    Anyone else run into this?
    I don't want to have to replace the SBU board if I can avoid it.
    Thanks for any input.
  • nmfaxman
    • 1702
    Re: Ricoh 2015 sc 144
    Sorry it is a ricoh 2051.
    • ragajungle
      SBU connector issue. SBU board or maybe the actual scanner lamp is burned out. I had that code on thesame mfp and the board was bad. I hadanother oneand it turned out to be the scanner home position sensor was flakey.
      • lupi
        • Aug 2011
        • 102
        try this
        The connector for the ARDF (Scanner section: Item 13) was making a poor connection. Replaced the connector, ARDF harness(ARDF parts manual: Drive section: Item 1) and ADF controller board (ARDF parts manual: Drive section: Item 2).
        • nmfaxman
          • 1702
          Turned out to be CCD unit. $100.00 from recycledparts.
          Told Tech to unplug from wall before working on any machine from now on.
          Thanks for feedback.
