How to reset to factory settings Ricoh Aficio SP3410SF?
How to reset factory settings Ricoh Aficio SP3410SF
neo_tt
Dooko
Re: How to reset factory settings Ricoh Aficio SP3410SF
1. Back up address books stored in the Ricoh copier settings that you may need. Using your owner's manual, follow the process to back up any information that you do not want to lose. Resetting to factory defaults will erase all stored data.
2. Press the "./*" key and the "#" key on the Ricoh copier at the same time and hold for 10 seconds. Nothing will seem to happen until you hold both buttons down for the full 10 seconds. Once 10 seconds is reached, the copier will shut down and begin to re-boot. During this process, the Ricoh is resetting itself to factory default settings.
3. Test to make sure the process worked. By going through the menu options on the screen, you should notice that your old settings have been replaced and your address books have been cleared. If this is the case, your Ricoh copier has been reset to factory defaults. If not, check your owner's manual as the process for some Ricoh's may differ from this process.
Good LuckComment
