Aficio 3228C can print but cannot scan
  • alansoon73
    • Feb 2011
    • 15
    Aficio 3228C that comes network printer and scanner is connected in a LAN environment. The copier can print but when we try to scan, the message " no response from scanner " appears. Already install the correct twain driver and Paperport 9.0. I know scan to folder is an option but wanted to find out why the paperport does not work. Thanks.
  • Herrmann
    • Jan 2006
    • 792
    Re: Aficio 3228C can print but cannot scan
    First at all, i would disconnect the Mashine from the Network, attach a Notebook to it and see, if this minimal configuration works.
    Did you do this already?
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • alansoon73
      • Feb 2011
      • 15
      Alreadt tried that and the scanning worked. So what could be the problem here ? Maybe the pcs in the LAN are protected by firewall ?
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Sure sounds like a firewall issue; port 1022 needs to be open.
        I don't remember if it's TCP or UDP, but open both to be sure. You can name them anything you want.
        • rthonpm
          • Aug 2007
          • 2849
          It sounds like a firewall issue, though you may also want to check whether or not the NIC firmware is up to date to allow the machine to work with NTLMv2. I know some environments have turned off NTLMv1 support as an added security measure. Also, make sure you're not trying to connect 64 bit clients with TWAIN as poor old TWAIN is an x86 only application.
          • pradeesh
            • Aug 2011
            • 10
            u had checked in device manager whether driver is updated ie havin yellow sign.......
