I have a issue with skew on print mode . It shows up mostly on 11x17 from end to end about 0.75mm . bottom hash marks are square. I am not extremely familiar with ricohs (sharp/konica tech). the customer reciently moved the machine to its present location it did have this problem before relocating according to them. I have checked all the trays..drives..rollers ect the skew is the same on print or copy mode. Is it the laser? what adjustment should I do first before I go too far forward? lead edge registration is close (other than the skew). duplex skew shows the bottom right lead edge on hash mark.
thanx for your help on this, Arnie
