aficio 2060 - Sc 122
  • Toshiba911
    • 24
    What does its mean sc 122 of Aficio 2060
    anybody help!
  • JustManuals
    • Jan 2006
    • 9838
    Re: aficio 2060 - Sc 122
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • jonhiker
      • 661
      122 D Scanner home position error 3The scanner home position sensordoes not detect the on conditionduring original scanning.
      BCU, SDRB (Scanner Driver Board)defective
      Scanner motor defective
      Harness between BCU, SDRB, scannermotor disconnected
      Scanner HP sensor defective
      Harness between scanner HP sensorand BCU disconnected
      Scanner wire, timing belt, pulley, carriageinstalled incorrectly.
      checked the scanner settings, but this may be fixed by shutting down completely and restarting.
      • Toshiba911
        • 24
        Thank you !
        • teebee1234
          • Jul 2008
          • 1670
          One thing to check is to make sure the set screw that locks the cable pulley to the scanner drive shaft didn't back out or shear off.
          • lupi
            • Aug 2011
            • 102
            SC122
            [Cause]
            SDRB board is faulty.
            [Resolution]
            Replace the SCRB board and ground.
            AND
            SC122 occurs while scanning.
            Does not occur when scanning at the same magnification; occurs when copying and enlarging.
            Answer
            [Cause]
            Scanner motor is faulty.
            [Resolution]
            Replace scanner motor.
            • Zoran
              • 52
              Replace or repair B247-5180
              • The CopyDoc
                • Oct 2012
                • 19
                A unit that old, probably a dirty Home Position sensor
