c 3500 touchpad calibration
  • tbcnsp
    • Aug 2011
    • 13
    Having trouble calibrating c3500. Any help?
  • Ianizer
    • Jul 2011
    • 380
    Re: c 3500 touchpad calibration
    How do you mean, Tbcnsp?
    Trouble locating calibration mode?
    Or trouble getting the screen to calibrate?
    If the former, please press Clear Modes - 1 - 9 - 9 - 3 - Clear(x5).
    If the latter, you can try reseating all connectors, but it's been my experience that the touch screen has failed.
    -I
    My name Peggy.
    You got problem?
    • lupi
      • Aug 2011
      • 102
      After clearing the memory, or if the touch panel detection function is not working correctly, follow this procedure to calibrate the touch screen.
      NOTE: Do not attempt to use items [2] to [7] on the Self-Diagnostic Menu. These items are for design use only.
      Answer
      1. Press the [Clear Modes] key
      2. On the number pad press 1 9 9 3
      3. Press the [Clear / Stop] key 5times
      4. On the touch screen press [Touch Screen Adjust] or press the [1] key.
      5. Use a pointed (not sharp!) tool to press the upper left mark6. Press the lower right mark after it appears.
      Touch a few spots on the touch panel to confirm that the marker (+) appears exactly where the screen is touched. If the + mark does not appear where the screen is touched, press Cancel and repeat from Step 4.
      7. When you are finished, press [#] OK on the touch screen (or press[#])8. Touch [#] Exit on the touch screen to close the Self-Diagnostic menu and save the calibration settings
      • tbcnsp
        • Aug 2011
        • 13
        Thanks, so far so good
        • sandmanmac
          • 3979
          There are problems with this whole line of touch screens. The new part number for Modified unit (if it becomes unresponsive again) is: B223 9900
