SC 548 error on MPc4500
  • idplus2
    • May 2011
    • 19
    Hi Everybody,
    Can you please remind me how to reset the SC548 error on the color ricoh MPC 4500?
  • mikadonovan
    • May 2008
    • 2931
    Re: SC 548 error on MPc4500
    Enter service mode and use sp5810 to reset fuser codes. You need to check the fusing belt sensor and make sure the fuser is set correctly. If those things look OK, you might have a bad IH inverter coil, which is a real pain to replace. I did one earlier this week and it took me almost 2 hours.
    NEVER ASSUME ANYTHING
    • TonerMunkeh
      Professional Moron
      • 3865
      Luckily enough 548 is more often than not a worn ferrite roller. Just do a fuser rebuild and that should sort it. There is a firmware update for this SC too, wouldn't hurt to do it.
      Hit it.
      • teebee1234
        • 1670
        I had this code last week and it turned out to be the encoder sensor on the frame. To confirm, I switched it with the one above it and the error switched to 549.
        • TonerMunkeh
          Professional Moron
          • 3865
          Yeah, there's a modified set of sensors for that too. AW02 0190.
          Hit it.
          • Ollie1981
            Toner Monkey
            • Mar 2008
            • 418
            Things to check before you reset because sc548 relates to a "fuser rotation error" :-
            1/ The orange sponge roller inside the fusing belt isn't starting to disintegrate, I've had a few of these come in for 548, the code has been reset then a couple of days later it's come back in again with a chewed up fusing belt because this roller has given out. If you have a load of orange dust/chunks in the bottom of the fuser, this roller is on it's last legs.
            2/ The bearings haven't seized (usually the press roller bearings but not unheard of for the aforementioned sponge hot roller bearings to go as well). These seize up on both this machine and the newer MPc4000/5000 machines. The machine will usually run but with a terrible clicking/clunking noise from the fuser as the whole bearing is effectively turning in the frame rather than the inner race turning with the roller. The press roller bearings can be a PITA to get off if they have seized and because the press roller is held captive in the frame by the bearings you have to get them off to remove the roller.
            3/ The sensors actually on the machine frame (RHS door at the front) aren't hanging loose out of their brackets, the modified sensors have increased the gap between the photointerruptor to prevent them being knocked loose if the customer doesn't push the fuser back in square at the back and front.
            4/ The oil supply and cleaning rollers aren't completely dry (oil) and caked in baked on toner (cleaning). I have had a few where they haven't been changed in a long time and had effectively stuck together and seized, this was putting a breaking effect on the press roller that seemed to be causing 548.
            • knightfall
              • Jul 2006
              • 633
              sometimes it is the encoder sensor gets knocked out when customer pulls out fuser unit and pushes unit back will knock sensor loose, just wanted to add that to all the other good suggestions out there.
              Get your facts first, and then you can distort them as much as you please.
              • lupi
                • Aug 2011
                • 102
                SC548 Fusing unit rotation error is displayed
                Question
                [Problem]
                SC548 Fusing unit rotation error is displayed.
                Answer
                [Cause]
                When the Fusing Unit is inserted into the machine, side to side play may allow the Fusing Rotation Encoder to hit the Fusing Rotation Sensor and knock the sensor out of position and/or damage the Fusing Rotation Encoder or Sensor.
                [Action]
                1. Check and replace if necessary the Fusing Rotation Sensor with Part Number AW020190. The width of the Fusing Rotation Sensor was changed (increased), to prevent the Encoder from contacting the Sensor (item 9 shown in lower right of picture below) when installing the Fusing Unit. Sensor is located on inner front frame and can be seen when removing the Fusing Unit.
                2. Check and replace if necessary the Encoder (item 33) Part Number B2234141
                3. Upgrade Engine Firmware to Version 1.551.01 or higher
                Symptom corrected:
                SC548 (Fusing unit rotation error) occurs if the fusing unit is not attached completely.
                Note: With the new firmware, SC548 is displayed only if it occurs three times during warm-up.
                OLD PART NO. NEW PART NO. DESCRIPTION QTY PAGE ITEM
                GW020020 AW020190 Photointerruptor: Lg248NL1
                2
                73
                9
                UNITS AFFECTED:All B222/B224 copiers manufactured after the serial numbers provided will have the new style Photointerruptor installed during production.
                Model Serial Number
                B222: Gestetner: DSc535 Lanier: LD435c Ricoh: Aficio MP C3500 Savin: C3535 L8976121492
                B224: Gestetner: DSc545 Lanier: LD445c Ricoh: Aficio MP C4500 Savin: C4540 L9076121226
                Technical Service Bulletin B222/B224 - 008 / 027
                • MCS3RD
                  I am having the same issue. The error follows the fuser. I replaced the actuator. NG. Fuser spins freely. Do not know what the IH inverter is. Can someone enlighten me please.
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    It might be the red sponge roller in the middle of the fuser is breaking down, the ferrite roller is on it's way out or the fuser bearings are starting to sieze.
                    Hit it.
                    • Llama God
                      • Mar 2009
                      • 1353
                      Replace the two sensors AW020190 on the frame and the two encoders (star-shaped and semicircular) on the fuser which actuate said sensors.
                      Then, and this is very important, UPDATE THE FIRMWARE.
                      Other than that, the fuser parts have a PM schedule of 160k so if they're anywhere near that, replace them.
                      • Ramón
                        • Mar 2011
                        • 26
                        To all those good ideas to solve this code I think you should also check these pieces Bushing AE03 1065: Fusing Sub-unit and also clean the vent fuser will probably be full of dust.
                        • MCS3RD
                          Thank you for all the suggestions. I swapped out the sensors on the frame, NG. If I put the fuser in another machine the code follows the fuser from machine to machine. I replaced the actuators and rebuilt the fuer. Still NG. Ugh! Kickin my butt and not happy about it. A known good fuser works fine in the machine.
                          • TonerMunkeh
                            Professional Moron
                            • 3865
                            When you say "rebuilt the fuser", what did you replace?
                            Hit it.
