Hi Everybody,
Can you please remind me how to reset the SC548 error on the color ricoh MPC 4500?
SC548 Fusing unit rotation error is displayed | |||||||||||||||||||
Question | |||||||||||||||||||
[Problem] SC548 Fusing unit rotation error is displayed. |
Answer | |||||||||||||||||||
[Cause] When the Fusing Unit is inserted into the machine, side to side play may allow the Fusing Rotation Encoder to hit the Fusing Rotation Sensor and knock the sensor out of position and/or damage the Fusing Rotation Encoder or Sensor. [Action] 1. Check and replace if necessary the Fusing Rotation Sensor with Part Number AW020190. The width of the Fusing Rotation Sensor was changed (increased), to prevent the Encoder from contacting the Sensor (item 9 shown in lower right of picture below) when installing the Fusing Unit. Sensor is located on inner front frame and can be seen when removing the Fusing Unit. ![]() ![]() 2. Check and replace if necessary the Encoder (item 33) Part Number B2234141 3. Upgrade Engine Firmware to Version 1.551.01 or higher Symptom corrected: SC548 (Fusing unit rotation error) occurs if the fusing unit is not attached completely. Note: With the new firmware, SC548 is displayed only if it occurs three times during warm-up.
UNITS AFFECTED:All B222/B224 copiers manufactured after the serial numbers provided will have the new style Photointerruptor installed during production.
