Ricoh A2045e server conection
  • bostjanma
    • Aug 2025
    Hi, I have problem with conection to server A2045e for scaning in to folder! Costumer changed server with new Windows 2011 server! If any tricks with this new windows? If I must change Firmware of the 2045e? I catch information that shuld be problem with SMB protocol in this server???? Any other sugestios? THX
  • rthonpm
    • Aug 2007
    • 2859
    Re: Ricoh A2045e server conection
    The copier does not support NTLMv2, which is the native SMB/CIFS protocol for Server 2008 and newer. The server will have to either be configured to allow for NTLMv1 connections only, or the customer will need to upgrade the machine.
    Some of my customers have set up a virtual 2003 server for issues like this, or set up an XP workstation as a scan server.
    • bostjanma
      Thanks, but please make me note which upgrade will be correct? Do you have any experience with upgrading? Im not shure if I must upgrade BICU or Engine or something else? I read all bulletines but I dont find idea wich upgrade will be ok????
      By
      • Herrmann
        • Jan 2006
        • 792
        In general, you should update all, because updating only a part of firmware can lead to unexpected problems.
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • TonerMunkeh
          Professional Moron
          • 3865
          By
          As rthonpm said, the version of NTLM this version of Windows uses is too new for the 2045. I don't think ANY firmware update will assist you. You will need to get the customer's IT to sort this one out, there's not much more you can do.
          Hit it.
