Aficio 1045
  • poz31
    • Aug 2006
    • 86
    Aficio 1045
    I'm working on an Aficio 1045, the machine is working fine. But the duplex is not active and the option is not shown on the screen.
    The duplex is plugged in and if I open it shows on the screen open.
    I remember about 4 years someone wrote about the same thing and I think this is an adjustment option on the Sp but do not which one...
  • bostjanma
    Re: Aficio 1045
    Do you check the pins inside the conector? It is very small and could be hapened to curved during conection.
    What hapened if you try check in SP 5-804-29,30,31 some duplex motors?
    • teebee1234
      • 1670
      Re: Aficio 1045
      It's more likely the HDD is bad/disconnected/missing.
      • Counsel
        • Aug 2011
        • 529
        Re: Aficio 1045
        is there an option in User Tools that turns on or off duplex copy/printing?
        • teebee1234
          • 1670
          Re: Aficio 1045
          Again, look for the obvious. Is the sort function available or missing also? If missing, then you have a Hard Drive problem. Print out the config sheet and check it for the HDD status or try and do a format of the HDD. Pull out the controller, is the drive installed/plugged in?
          • JustManuals
            • Jan 2006
            • 9838
            Re: Aficio 1045
            Paul@justmanuals.com
            • +ve charge
              • May 2008
              • 87
              Re: Aficio 1045
              Agree with teebee, pls check for HDD malfunction as this disenables the duplex function.
              • leo34staffs
                copierman
                • Aug 2007
                • 503
                Re: Aficio 1045
                None of the pins on the duplex female connector are bent are they?
                • leo34staffs
                  copierman
                  • Aug 2007
                  • 503
                  Re: Aficio 1045
                  missed that someone else had put this!!!
                  • Ricoh-ono
                    • 339
                    Re: Aficio 1045
                    I agree with teebee1234. It's probably the Hard Drive.
                    Do what you can, with what you have, where you are. ~Theodore Roosevelt
