cl7200 fuser message
  • zspyder
    Hi fellow techs, I replaced a fuser in a cl7200 because it said it was time to replace type c fuser, how do I clear the message ?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    New fusing units have a spring that makes a circult.
    When the rollers turn for the first time the spring disconnects breaking the circult which tells the machine it a new unit and it resets the PM counter automatically.
    Alternatively you can manually reset the fuser PM counter using SP7804-016.
    Or you can take plastic top off the fuser and reconnect the spring clip next to the gears.
    • zspyder
      cl7200 fuser
      thanks for the reply, however I don't know how to get into the mode to reset the fuser count. I have to service this machine with NO manuals at this time for a customer so any help is GRAITLY apprecheiated.
      • Cipher
        • May 2006
        • 1309
        Reset the spring on the fuser, it does the same thing.
        • zspyder
          Thanks DaZ, however that did not work. the original fuser did not have a spring at the end. the new fuser does but it is still atattched. I don't know how to enter service mode to manually reset the count. Any ideas.
          • Cipher
            • May 2006
            • 1309
            Yup look it up in the service manual.
            • Scott_Lewis
              • Mar 2007
              • 519
              Checkout section 5.1.1 and SP5803 of the service manual.
