savin 2522 SC 984
  • yannii33
    • 121
    savin 2522 SC 984
    The machine only has copy with no harddrive and ricohsaid to replace the laser which I did and still have this code. Any suggestions would be great thank
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: savin 2522 SC 984
    Check and re-seat all the wire harnesses on the SBCU PCB / if that does not work replace the SBCU PCB.
    • lupi
      • Aug 2011
      • 102
      984
      D
      Print image data transfer error
      After a data transfer begins from the controller to the engine via the PCI bus, the transfer does not end within 15 s. Controller board defective
      BICU defective
      BICU, controller disconnected
      984
      D
      After a data transfer begins from the controller to the engine via the PCI bus, the transfer does not end within 15 s. Controller (SIMAC) board defective
      BICU defective
      BICU controller disconnected
      • nfcopiers
        • Sep 2011
        • 37
        sir help
        how to reset the counter of my ricoh 2015 or 2018...thanks
        alot
        • lupi
          • Aug 2011
          • 102
          Originally posted by nfcopiers
          sir help
          alot
          PM CONTER RESET BA PRE?
          PM Counter Rest Procedure
          Answer
          SP7804 PM Counter Clear - Do this SP to reset SP7803 (PM Counter).
