height doctor blade aficio 2090-700-1075
  • medallo
    • Dec 2008
    • 21
    Hello.
    Please what is the height of doctor blade of aficio 2105-700-1075.
    in the manual service are not.
    can be measured with gauges of some U.developed new.??
    Thanks for any help.
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: height doctor blade aficio 2090-700-1075
    I can't find any info about this either. I would imagine the easiest way would be to clean out a unit that is working fine and measure the gap with a set of feeler gauges.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • zed255
      How'd ya manage that?
      • 1024
      I've measured gaps on the 2090 and 2075 units and have found it to be 0.45mm. They are however factory set and aren't supposed to be adjusted which explaind why there is no spec or proceedure in the SM.
      • medallo
        • Dec 2008
        • 21
        sometimes they are required to remove the rollers move magnetism,or when disarming U.R,etc.
        if in the new 2090-2075 is 0.45 mm, this is the measure. is a measure of need.
        know those of 700-1075?mm?
        your help is very good.Thank you.
        • mikadonovan
          • May 2008
          • 2931
          I have replaced mag rollers on a 2051 and 1075 - set the gap to .040.
          NEVER ASSUME ANYTHING
          • anpetros
            • May 2011
            • 43
            You can adjust between 0.50 and 0.55 on aficio 700. The general rule is that if you leave a big gap developer will be spilled out.If too small you will have toner spilling out on the front side of the magnetic rollers due to lack of magnetic brush created by the developer.For the aficio 1075 is 0.40 to 0.45.The rule here is the same.
            • medallo
              • Dec 2008
              • 21
              thanks ..
              for your help.
              • medallo
                • Dec 2008
                • 21
                thanks ..
                for your help.
                very important.
