sc220 on mp7000 driving me crazy
  • T911
    • Jun 2007
    • 628
    replaced-ipu, entire laser unit assly, bcu, door switches, and entire wire harness from laser diode to ipu. driving me crazy. help appreciated
  • T911
    • Jun 2007
    • 628
    Re: sc220 on mp7000 driving me crazy
    anyone have bulletin 127 out of the b246 series manual they can shoot over to me. thanks t
    • mikadonovan
      • May 2008
      • 2937
      Not sure this will help.
      NEVER ASSUME ANYTHING
      • RICOHTEC
        • 42
        A. Damaged wiring harness between IPU and BCU PCB. Pin 2 (LD Monitor signal) of the IPU side of the harness which plugs into CN 347 becomes damaged from improper opening and closing of the controller box.
        B. The Laser Diode Unit has failed
        [Action]
        A.Check the condition of IPU BCU Harness (B247 5451) if damaged replace it
        1. Disconnect ADF cable
        2. Remove the Rear upper cover (2 screws) and Rear lower cover (2 screws)
        3. Remove screws 1 to 4. and swing open the controller box
        4. Remove the left IPU connector shield (item 5) (2 screws).
        5. Carefully disconnect connector 347 (item 6)
        6. Inspect wiring for pin 2 (upper left wire) for damage and repair or replace as needed.
        B. Check and replace the Laser Diode Unit. (B2471859) if necessary.
        • T911
          • Jun 2007
          • 628
          [Action]
          Thanks much I will check on it monday.
          • spaniel ears
            • Jul 2010
            • 79
            Did you ever resolve this problem? I've got a machine with the same intermittent fault at the moment.
            • nobody-here
              • Mar 2008
              • 237
              Italian Ricoh Spare Parts Site is telling me that new laser diode code is B2471840.
              Is it correct ?
              Vincenzo
              29 rouge unpair manque.... cous cous....
              • Polo-022
                • Sep 2007
                • 481
                I have to report sporadically SC-220 from an MP-6000 lately, just copier, 700K copies, but till now i am waiting for a worst code to act...!
                • RICOHTEC
                  • 42
                  SC 220 Laser Synchronization Detection error
                  [Cause]
                  Defective SBU
                  OR
                  DOOR SWITCH
                  [Resolution]
                  Replaced SBU which is part of the Lens Unit B247 1721
                  OR DOOR SWITCH
                  • Polo-022
                    • Sep 2007
                    • 481
                    It's time to take some action with this (SC-120) problem!! I see this code coming up when i switch on the copier, immediately, sometimes it works for a while and it drops out a blank page...(MP-6000)
                    There are codes SC-990 and SC-355 (too many) logged also. Drum is covered with a thin layer of toner and i suspect an imitation toner in the 'original" bottle...
                    Does anyone from above have the same symptoms?
                    I ask this because i see that many suspicious parts have been replaced without success....
                    So where is the beginning...
                    I don't use to, but i am thinking for an NVM clear and reflash..
                    What do you think about?
                    • Tuga
                      • Mar 2012
                      • 35
                      HI
                      I also had a sc220 on a MP7000.
                      Try chek the thermistors on fusor,replace them.
                      Ok,OK this is weirdbut with thermistors damaged the fuser temperature rises too much and affects the unity of Laser that just above.
                      I think that causes a binding on the laser unit
                      I hope it was useful.
                      Filipe
                      • Polo-022
                        • Sep 2007
                        • 481
                        Hi Tuga, everything goes...sometimes.
                        Today i had this SC-220 code permanent at switch on. I could hear the laser motor spinning.
                        I did replace both door switches -as an assembly- first of all and while i was trying to disengage from the SC-220, I saw some hidden SC-551 codes..., by pulling out the fuser module, resseting and doing an SP 7-807, this code dissappeared...I thought that operator did not push firmly in the fuser module..
                        Thanks for the info, i'll be back..
                        • Polo-022
                          • Sep 2007
                          • 481
                          I have to close this post with the final solution : Ιt was the Laser Diode Unit faulty!! (B247-1840)
                          Too expensive...
                          • hsh6049
                            • Jul 2012
                            • 64
                            Too expensive...
                            so finally is duesto laser diode unit cause sc220?
