Ricoh Aficio CL3500N - Color Register Error
  • DIONISIS
    • Oct 2008
    • 17
    #16
    Originally posted by agapecpus
    This is the solution from Ricoh website which did not work:
    Please press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust. If after completing the procedure the error persists, please contact your service representative for support.
    Have any suggestions?
    try in drum section the -line position adjust-
    execute the 3parametres,then try color reg in maintenance(the first and second wiil be failled but the third will complete)
    DIO-masterprint
    • Saviour
      • Oct 2008
      • 57
      #17
      just had this problem this week. this printer has been giving this problem since it was shipped and tried and checked every unit to try to solve it but the only thing that solved the problem for some 2K cycles was replacing the color drum. this week i decided to to dig deep and behold the first thing i notice is that when sliding the PCu shutters back tom open position, the MAgenta was looking empty or low so i then shifted attention to the the toner supply shutters at the top of the machine and again found that whilst Cyan and yellow toner fell out of the whole length of the shutter the magenta only fell from the back slit only. cleaning the toner feed tube throughly after removing the whole assy solved the problem but still had to replace the PCu as this would not come back to spec and color registration was never right, so prints would be lacking magenta or no magenta at all. hope this helps
      Voluntary assistance can be your greatest gift once you do not degrade the recipient.
      • Saviour
        • Oct 2008
        • 57
        #18
        CL3500 reg error
        Did you manage to solve the poblem
        • Saviour
          • Oct 2008
          • 57
          #19
          cl3500 color reg error
          Did you eventually manage to solve the probem?
          • nicko
            #20
            inserting the rong pcu
            Originally posted by jasonsams
            i have found through several issues that you may get this error. No matter what it is caused by rather the color pcu or the transfer belt. If you have not tried to replace these it is a place to start. Once it was due to the customer ordering the wrong color pcu and installing it. The other time was that the transfer belt was not properly seated. Sometime just pulling the new belt out and reinstalling can fix this issue. If the belt is on an angle or has too much tention it will not move properly thrus causing the color regist. Error. I hope this helps.
            i have inserted the rong pcu....but when i insert the correct one the alignment still fail how do i solve that
