nop.Check the parts catalog.All boards are the same.
Yes, but the software/firmware these machines run on is different (on the 75 cpm machine the interval between the paper is shorter). Don't waste your time, there's no easy/cheap way to do this.
Dear Eric ,the firmware for those copiers is THE SAME......
At the back of BCU board, you can find a CNB board, look for a six pin connector, four of the wire are black color, short the first and the third wire. It will change it to 75 copies.
That doesn't mean that you can change the copy speed. For example the firmware file for the Kyocera Taskalfa 250ci/300ci/400ci/500ci is for all models the same, and still I can't make a 25 cpm machine run at 50cpm.
Can we do that or something similar on mp5500,6500,7500?
You really need to ask yourself is it worth it? Im sure you can find a cheaper paper weight.
"Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
