Aficio MP2000 Scan to folder in Windows 7 fails
  • sandmanmac
    • 3983
    [Misc] Aficio MP2000 Scan to folder in Windows 7 fails
    Ok.
    I had this problem previously on an MP161, and determined that for whatever reason, something seemed to be wrong with the SD card, because I had 2 machines both with the same updated firmware. One scanned no problem to windows 7 , the other one wouldn't at all. Swapping SD cards reversed the results.
    I now have an MP2000 that was scanning, but not reliably. In other words, it worked about 50% of the time on Windows 7. I updated the firmware, and now it fails every time (The usual message: "Sending failed. Check settings..."etc.).
    I think that I have the most updated firmware, but I'm wondering if maybe I don't in this case, and perhaps this is causing the glitch. I've recently lost access to The TSC site as many/ most independents have.
    I've listed the currently installed firmware below, and I'm wondering if someone might have a look at them, and tell me if it is, in fact, current (particularly the scanner, I suppose), and if not, maybe that someone might be able to help me in obtaining the updated firmwares.
    Also, if anyone has experienced a similar case, and found the solution. I'd be very interested. I sure didn't expect to make the issue worse with a firmware update
    Thanks a lot!
    Aficio MP2000
    Fax 02.00.00 B2765522B
    Security Module 1.02 B2765523A
    System/Copy 1.12 B2765521K
    SD#1 PCL Font 1.00 B7675383
    Fax(option) 02.00.00 B8675524B
    SD Scanner 01.09 B8675525E
    Network Support 6.16 B8675526G
    Web Support 1.02.3 B8675527B
    Network DocBox 2.01 B8675528C
    Printer 1.10 B8675540E
    GWFCU3-7(WW) 03.00.00 B8685570C
    Engine 0.21:06 B2765540B
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Aficio MP2000 Scan to folder in Windows 7 fails
    Fax - up to date
    Security Module - up to date
    Printer - up to date
    BICU (Engine) - up to date
    System/Copy - v1.13
    NETFile (Network DocBox) - v2.03
    NIB firmware (Network Support) is at v6.17 and has a lot of scan to smb fixes (see attached).
    Websystem (Web Support) - v1.07
    Scanner - v1.10
    • sandmanmac
      • 3983
      Exactly what the problem was....thanks a lot!
