How do I get the image of the fax I just sent to show up on the fax confirmation sheet? Is the information as to how in the owners manual, or is it in SP mode? If in SP mode where do I go to make it do so? Any help appreaciated, thank you.
Fax Option Ricoh Aficio 1035
Re: Fax Option Ricoh Aficio 1035
Enter SP mode, go to Fax Features and select Bit Switches. Find the Printer Switches
Printer Switch 0E
Printing the sample image on reports
Bit 4 Bit 3 Setting
0 0 The upper half only
0 1 50% reduction in sub-scan only
1 0 Same size
1 1 Not used
“Same size” means the sample image is printed at
100%, even if page separation occurs.
User Parameter Switch 19 (13H) bit 4 must be set to
“0” to enable this switch.
6800E3(H) - User parameter switch 19 (SWUSR_13)
Bit 4: Reduction of sample images on reports to 50% in the main scan and subscan
directions. (This switch is not printed on the user parameter list.)
0: Technician adjustment (printer switch 0E bits 3 and 4), 1: 50% reduction
