MP 9000 SC495
  • zoran.riko
    • 54
    MP 9000 SC495
    the two waste toner bottles are empty, what to chek for this SC ?
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: MP 9000 SC495
    SYMPTOM
    SC495 occurs after the machine is used for a while.
    CAUSE
    The toner supply tube is not in the correct position and is also bent (assembly error at the
    factory).
    SOLUTION
    Do the following at machine installation:
    Procedure 1: Checking the Position of the Toner Supply Tube
    From the rear side of the machine:
    1. Open the PSU Box (screw x 2).
    2. Remove the Rear cover (screw x 4).
    3. Remove the Fly Wheel (screw x 3).
    4. Remove the ADF Plug Bracket (screw x 4, Connector x 5).
    5. Remove the Air Duct Unit (screw x 2, connector x1).
    6. Make sure that the toner supply tube is in the correct position.
    Correct position:
    The tube is to the left of the connector in the photo.
    Procedure 2 below.
    Correct position:
    The tube is to
    the left of the connector.
    Incorrect position:
    The tube is on top of the connector.
    Nobody is perfect..
    • Polo-022
      • Sep 2007
      • 486
      Re: MP 9000 SC495
      Remove and clean toner pump and toner tubes, you may have to replace the pump for better results..
      • withnail
        • 59
        Re: MP 9000 SC495
        Clean and vacuum ALL the toner pipes to cure this fault.
        I vac out back to the toner pot at the top of the toner bank auger.
