MPW 2400 background
  • knarfdnul
    • Apr 2011
    • 27
    [CQ] MPW 2400 background
    Hi Everyone. I have one with background like damaged developer even after changing developers and cleaning 11000 meter maintenance.
    Any ideas?
    Knarfdnul
  • totoro
    • 568
    Re: MPW 2400 background
    What's the count on the drum? I had a 470w like that and it took a drum change to set it right.
    Totoro
    • knarfdnul
      • Apr 2011
      • 27
      Hi Totoro.
      The count for all drum unit parts are 13000 metres (about 42000 feet) - no drum parts have yet been changed.
      • totoro
        • 568
        It looks like the parts are the same for the 240w and the drum yield for that is 40k. You might need to change the drum, cleaning blade, and the rest of the around drum pm parts.
        Totoro
        • jdzr
          • 125
          Drum will definitely give you that kind of a problem as well as a problem with the ID sensor.
