Hi
I installed an MPW 5100 with a compact 3 folder unit.
One problem is that when i use HDI driver sometimes (depending print size) the machine rotates my print and then the fold on compact 3 is made incorrectly.
Where do i disable auto rotation for hpgl/2
Another problem is that if the roll paper is larger then the drawing the machines centers the drawing. So i went o HPGl/2 Tiff setting on expanded features and disabled the "center print".
The problem is that the image shifted to the wrong side off the paper. The white unused margin stays under the legend of the drawing.
In the preview of the autocad is correct.
Uploaded with ImageShack.us
It's my first Compact 3 installation.
Any Ideas???
Any Ideas???
