Aficio 3260c SC530
  • zoran.riko
    • 54
    Aficio 3260c SC530
    HI,
    I can`t find in manual what SC 530 means so, I replace the whole set of termofuses and termistors and still after few seconds showing SC 530. The fusing lamps are working and they are OK. Any suggestions PLS ?
  • rthonpm
    • Aug 2007
    • 2854
    Re: Aficio 3260c SC530
    SC 530 is a fuser fan error. Check the connections to all fans, and also try flashing the firmware.
    • zoran.riko
      • 54
      Thanks on quick reply, I am almost shure that the fan is the problem. Thanks again
      • Lagonda
        • Aug 2008
        • 1649
        Check the fuser cooling fan on the left hand side of the copier at the rear of the fuser, paper get jammed into it when they slam the fuser home without clearing all the paper scraps.
        • zoran.riko
          • 54
          TNX for answering on My thread, I replace the fuser fan and now is working fine. Thanks a lot.
