LP127n/LP128n not printing
  • digicor
    • Jul 2008
    • 1159
    this printer boots up and revs up and then finishes, but wait! theres no document coming out!!
    theres no job in cue! the machine thinks its done but it hasnt done anything!! i have the latest driver.
    it only has 1045 prints on it as well, any ideas? is there a firmware fix or malfunction to re set?
    thanks
  • rthonpm
    • Aug 2007
    • 2859
    Re: LP127n/LP128n not printing
    What is the OS of the computers printing to the device? What driver are you using? Also, try changing the port from RAW to LPR, the queue name is lp. Sometimes that seems to make all the difference in the world to Ricoh equipment.
    • digicor
      • Jul 2008
      • 1159
      the os is windows xp the driver is the only one i can find online a uni pcl6...
      ill try the other, lpn and lp for the thing and see if this does it, ive had this happen on a minolta color machine once, thanks for the reminder...
      • rthonpm
        • Aug 2007
        • 2859
        The Lanier website shows PCL 5, PCL 6, and PostScript drivers available for the LP128. I'd recommend PCL 5, or PostScript (don't remember if this one needs a PS chip or has an emulator.
        • coolbeer
          • Jul 2011
          • 100
          Check for user codes on printer in web browser.
