AF2020 & WINDOWS 7
  • +ve charge
    • May 2008
    • 87
    AF2020 & WINDOWS 7
    Hi... Need help with the following problem. AF2020D was printing/scanning perfectly when connected using windows XP version (with internet cable). Customer has now upgraded to Windows 7 and I cannot get it to detect printer and scanner drivers. I'm using desktop binder. Am I missing something? Even if its a simple and obvious answer, yr response will be appreciated ..... thank you.
  • rthonpm
    • Aug 2007
    • 2859
    Re: AF2020 & WINDOWS 7
    The AF2020 does not support NTLMv2, which Windows 7 uses to allow incoming connections. TWAIN also will not work as this is not supported in the 64 bit platform. You could try scanning by IP address (i.e. 10.102.135.14\Scans) as opposed to host name, but without NTLMv2 you probably won't have much luck. Technology has passed this model by.
    • rchdesk
      • 46
      First off. Make sure you're using the latest firmware. That was an ongoing problem from Ricoh and was fixed with a firmware update. Then, the user on windows 7 most have password (no blank password). Also, disable any firewall (Windows or Antivirus).
      If none of this works, you can still scan to ftp. Download Filezilla, a free ftp server, install it and scan to it. It is ease and practical.
      • +ve charge
        • May 2008
        • 87
        Thank You Gentlemen.... I will try both suggestions. Deeply appreciate yr inputs.
        • +ve charge
          • May 2008
          • 87
          Re: AF2020D & WINDOWS 7
          Hi Again... I'm on the same subject. I have got the machines to print using the USB connection but I have a strange occurrence (to me at least), On one machine I have the duplex icon appear in the printer menu and can duplex prints but on another machine I don't get the duplex icon appear on the print menu?? Need yr advice. thanks
          • Jomama46
            • 2900
            Go to the accessories tab on the printer properties and add the duplexer
            sigpic
            A+; Network +; PDI+
