which model is the best?
  • miro
    • Feb 2010
    • 87
    Re: which model is the best?
    Originally posted by cleardata
    any comments/issues about the performance of ricoh aficio 2045, 3045 and mp4500?
    2045 ok
    3045 ok
    mp 4500 same maschine , but new type of toner and developer , with some problems with new toner and developer ( same type is on new mp 4000 (4001) and mp 5000 (5001).
    • Ollie1981
      Toner Monkey
      • Mar 2008
      • 418
      2045 and 3045 ok but dirty running, copy quality is good with parts within life, engine is virtually identical between the two but if budget allows choose the 3045 for newer connectivity features.
      MP4500 ... don't touch it with a sh*tty stick, same engine but the toner/dev mix causes them to be a more of a toner dusting pig than the previous models, also the CQ is generally worse than the preceding boxes, avoid like the plague!
      • cleardata
        • Jul 2011
        • 137
        thanks guys. can the aficio 2045 or 3045 reach about 2million or 3million clicks before it can be junked? any idea what's the highest clicks it can reach?
        • Max
          • Oct 2011
          • 548
          #19
          2045
          3045
          mp 4500 same machine Those machines are coal mines make sure you have a bio suit so service them.
          You must be mad to go for those things.
          • TonerMunkeh
            Professional Moron
            • 3865
            #20
            The 3045 will easily reach 3 million if, and only if, it is serviced correctly and run with OEM toner and parts. PCU rebuild every 150k, developer every and associated seals 300k. Hot roller, pressure roller, thermistors and cleaning roller on condition, but keep the cleaning roller nice and shiny. Empty transfer waste and clean bias roller every 150k. If you keep an eye on the toner leaks, make sure they don't go anywhere near the laser, they will run like a tank. Above all, keep it clean!
            Hit it.
            • knightfall
              • Jul 2006
              • 633
              #21
              Originally posted by TonerMunkeh
              Look for a used MP5500. They're bulletproof. Make sure they get serviced on a regular basis, use OEM toner and load the paper properly, you will rarely, if ever, have a problem with it.
              put that in a public school and you'll find it full of bullet holes.
              Get your facts first, and then you can distort them as much as you please.
              • miro
                • Feb 2010
                • 87
                #22
                I have few 1045,2045 and 3045 with 6 milion on counter
                • cleardata
                  • Jul 2011
                  • 137
                  #23
                  wow that's great miro! what are the problems you always encounter with these models?
                  any suggestions on how to maintain it? how you were able to make it reach 6million?
                  i have aficio 1045 also but i encountered some problems with power supply 220v because it gets busted, main motor sc440, high voltage sc395 and polygon sc320.
                  these are mostly the problems i encountered with aficio 1045.
                  im very interested to know how you handled these models.
                  • BLADE
                    former propeller tester
                    • 478
                    #24
                    I have one of these in a public school admin area, been there nearly 5 years, just over 1 million prints (not a record I know) but has only had one service call logged on it (945 k) It has had programmed maintenance calls for webs etc. But the user has only rang in once with an issue.(some sort of record in my area). The strangest thing is the machine runs properly and stays clean.......(o oh the phones ringing)
                    • mark777
                      #25
                      yes Aficio 3030 very easy to maintain
                      good machine overall
                      • vinli
                        • Nov 2011
                        • 11
                        #26
                        aficio3030 shb be good enough,not much issue printing @10k a month, mp4000/mp5000 is the best after rectifying their toner issue
                        • cleardata
                          • Jul 2011
                          • 137
                          #27
                          hi vinli,
                          what's the solution to the toner issue?
                          • TonerMunkeh
                            Professional Moron
                            • 3865
                            #28
                            There isn't a resolution yet. Not a firm one anyway. If you're going to go for one, keep a couple of hundred bags of developer, an angle grinder and half a dozen developer units on standby. Oh, and a biochecmical warfare suit.
                            Hit it.
                            • BLADE
                              • 478
                              #29
                              after reading some of these posts i think someone should tell the big R people that monocomponent black n whites might be the way to go
                              • vinli
                                • Nov 2011
                                • 11
                                #30
                                hi vinli,
                                use 2035 toner & developer,change hopper motor to 2035 hopper motor
