which model is the best?
Re: which model is the best?
MP4500 ... don't touch it with a sh*tty stick, same engine but the toner/dev mix causes them to be a more of a toner dusting pig than the previous models, also the CQ is generally worse than the preceding boxes, avoid like the plague!Comment
The 3045 will easily reach 3 million if, and only if, it is serviced correctly and run with OEM toner and parts. PCU rebuild every 150k, developer every and associated seals 300k. Hot roller, pressure roller, thermistors and cleaning roller on condition, but keep the cleaning roller nice and shiny. Empty transfer waste and clean bias roller every 150k. If you keep an eye on the toner leaks, make sure they don't go anywhere near the laser, they will run like a tank. Above all, keep it clean!It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
put that in a public school and you'll find it full of bullet holes.Get your facts first, and then you can distort them as much as you please.Comment
wow that's great miro! what are the problems you always encounter with these models?
any suggestions on how to maintain it? how you were able to make it reach 6million?
i have aficio 1045 also but i encountered some problems with power supply 220v because it gets busted, main motor sc440, high voltage sc395 and polygon sc320.
these are mostly the problems i encountered with aficio 1045.
im very interested to know how you handled these models.Comment
I have one of these in a public school admin area, been there nearly 5 years, just over 1 million prints (not a record I know) but has only had one service call logged on it (945 k) It has had programmed maintenance calls for webs etc. But the user has only rang in once with an issue.(some sort of record in my area). The strangest thing is the machine runs properly and stays clean.......(o oh the phones ringing)Comment
mark777
There isn't a resolution yet. Not a firm one anyway. If you're going to go for one, keep a couple of hundred bags of developer, an angle grinder and half a dozen developer units on standby. Oh, and a biochecmical warfare suit.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
