scan to gmail from ricoh
  • iscott
    • Mar 2010
    • 344
    Trying to set up a Ricoh MP C4000 to scan to gmail I have a document from Ricoh that is supposed to tell me how but it has not worked. The first thing about the instructions that looks wrong on the screen shot of the Copier operation panel under Tools =>Systems Settings=>File Transfer=>SMTP Server I am suppose to have a "Use Secure Connection (SSL) On or Off option which does not apperar on this screen on my MP C4000 (all firmware is up to date).
  • mrwho
    Major Asshole!
    • 4299
    Re: scan to gmail from ricoh
    Try this one. Haven't used it myself, but I've been told it works.
    EDIT: Sorry, didn't read all of your post at first, so I'm not sure if this will help you, but since I don't have an MPC4000 at hand, that's all I can suggest for now. Sorry.
    Mascan42
    Ibid
    • iscott
      • Mar 2010
      • 344
      Thanks thats the same document I had only not in color...it does look better.......the only thing I see is the we have and lettered address (something like "gmail.smtp) instead of an IP in the server name
      • jac_0101
        • Jun 2009
        • 4
        if the model does not have the ssl appear under smtp you need a newer machine
        • TonerMunkeh
          Professional Moron
          • 3865
          Ping the server and use the IP it gives you. That usually sorts silly problems out.
          Hit it.
          • cobiray
            Passing Duplication Xpert
            • Mar 2008
            • 1199
            Check out stunnel.org and read this doc. We have been giving it to our customers who have non-SSL machines and are upgrading to or otherwise now using SSL enabled email servers.
            Stunnel Setup.pdf
            • iscott
              • Mar 2010
              • 344
              But the MP C4000 is supposed to have SSL.......Doesnt it?
              • cobiray
                • Mar 2008
                • 1199
                If it has SSL it is turned on or off on the SMTP screen directly under the SMTP address.
                • techsass
                  • Dec 2010
                  • 248
                  The 1st models I know of to support SSL are the newer c300 & c5501.
                  If you do a search there are posts about gmail workarounds. Basically changing the SMTP server to aspmx.l.google.com on port 25 (note that is not SSL) and changing the account settings to "Don't always use https".
                  • mrwho
                    Major Asshole!
                    • 4299
                    Thank you very much. I wasn't aware of that possibility. I'm going to try it the next time a customer with an old equipment asks me to use gmail!
                    Cheers!
                    Mascan42
                    Ibid
                    • techsass
                      • Dec 2010
                      • 248
                      I mainly use a gmail acct. I setup to convince customers that the copier's scan to email works fine when I get bogus smtp info.
                      • patterson70
                        • May 2010
                        • 602
                        I had trouble downloading the Site Certificate because it would not show up as in the last step shown in the instructions (thank you for those!) Do you have to be Ricoh tech for them to send it to you?
                        • iscott
                          • Mar 2010
                          • 344
