Firmware update on MPC4501 went wrong
  • TCA TECH
    • Mar 2009
    • 104
    Hi all,
    Just updated the firmware on a MPC4501 , rpcs, pcl, printer, engine, and part of that was to do finisher.
    After I finish the sorter is not recognised by the machine, any idea's.
    Copiers are only as good as there last service
  • teebee1234
    • 1670
    Re: Firmware update on MPC4501 went wrong
    Do you get an error that the finisher isn't attached (sc7xx) or does it not even recognize that the bridge unit is installed either? Is their another compatible mfp nearby that you can plug the finisher into to isolate the issue?
    • TCA TECH
      • Mar 2009
      • 104
      yes a C792 error with bridge still fitted, the firmware version no longer shows on control panel.
      I am in the process to try a machine finisher from the office.
      • teebee1234
        • 1670
        Yeah, it sounds like the finisher controller got corrupted. That happened to me before, I think you will need to replace the finisher controller board. Did you do the finisher firmware last? I'm pretty sure it needs to be done after Engine and System are installed.
        • TCA TECH
          • Mar 2009
          • 104
          no we did it first, good lesson learned.
          • BLADE
            former propeller tester
            • 478
            a firmware number mismatch may have occured
            • TCA TECH
              • Mar 2009
              • 104
              Swapped ot the finisher and all works ok, Will return back to office and once resolved I'll update.
              Thanks for the advise
              • Oze
                Ricoh Fanboy
                • 1663
                Damn...and I was gonna drive down the coast and sort it too.....there goes mah weekend at Coffs
