Fusing unit rebuilds
  • blanka
    • Aug 2011
    • 34
    Does everyone else out there rebuild AF 1022 to 3025 range fusing units and if so do your fusing roller bearings knock even after you apply Barrieta grease. Or are fusing units replaced as a complete assy.
  • zed255
    How'd ya manage that?
    • 1024
    Re: Fusing unit rebuilds
    I rebuild 'em and don't have any issues with them knocking, just don't be frugal with the Barrierta grease.
    • Eric1968
      • 2458
      I also rebuild them. You can also use the bearings of the AF2035. They run smoother.
      • rthonpm
        • Aug 2007
        • 2859
        I agree with Eric. The added bonus of using the 2035 bearings is that the extra shoulder on the bearing will help to keep the heat tube in place in the event of the plastic frame breaking.
        • ash_572
          • Oct 2008
          • 523
          good idea with the 2035 bearings. iv had plenty where the fuser frame snaps. 2035 bearings will be perfect to stop this from happening. i will try this next time. thanks
          • duct tape
            • Jun 2009
            • 87
            Also you can use rvt gasket silicon on the ends of the hot roller then put on the bearings, this stops the noise. Just put a small ammount all the way around the roller, then reassemble the unit, It's worked every time.
