Strange jamming at 3025
  • kassa
    • Oct 2008
    • 79
    [Jamming] Strange jamming at 3025
    Hello guys and sorry for my bad english.
    I opened this thread because I have a 3025 with a strange problem of jamming.
    We'll explain:
    the problem occurs only on the second tray, but not always. Maybe jams do not occur for a whole week, instead of a few days very often. No matter how much paper there is in the tray.
    The paper never comes to the registration roller, but it almost always jamming at the second transport roller vertical or shortly before.
    The paper does not meet any obstacle as it has no scratches or marks.
    In any case, I replaced the paper feed roller, the paper feed motor, the main spring, I also tried to replace the entire paper tray and I also cleaned the second sensor paper transport, and clean the paper transport rollers, and greased their bushings.
    I was thinking of trying to replace the clutches of the feed roller and vertical transport.
    You have other suggestions?
    Thanks in advance.
    Bye bye.
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Strange jamming at 3025
    then replace the clutches
    Nobody is perfect..
    • vargue
      • Oct 2011
      • 404
      solution
      i meet this threat befor i swaer to yo that i let this customer for one day and come to him after 1 day i find out it's working without changing any parts good luck
      • totoro
        • 568
        Check and make sure that the rising unit plastic coupling hasn't cracked. Part # B029 2780.
        Totoro
        • zed255
          How'd ya manage that?
          • 1024
          +1 for that, seen a number of those break lately.
          • blanka
            • Aug 2011
            • 34
            No offence but surely you cannot be a technician.
            • zed255
              • 1024
              Who are you addressing?
              • blanka
                • Aug 2011
                • 34
                Im addressing Kassa!!
                • sharpmind
                  • Sep 2009
                  • 478
                  I don't think it is right to say those words to our fellow technician. Why don't you give good ideas to help him instead of belittling comment.
                  Are you sure you are not asking for help from other technicians in your company when you have problem in the field??
                  How can he grow more if we are not going to teach him?
                  I would say that I learn a lot from this forum. I thank those guys who share their ideas and insights about printers/copiers.
                  • blanka
                    • Aug 2011
                    • 34
                    Sharpmind, Did you not read my post, NO OFFENCE!! But im not going to start a argument online cause i will win anyway. Just remember that all that use this site are not techs and are just cheap skates who try and get info to fix their copiers and and end up causing more damage and when a tech is called out has to retrace the unknown. Mate if i had a tech come and ask me this i would get them to read the manual in detailed descriptions to see how the mach works. Obviously this tech has not even done that. As for me i do ask questions and most times even tech support cant even answer them. But hey like i said No offence. If your offended then maybe you should not read my post.
                    • rsyarcia
                      • 711
                      NO OFFENCE,Are you a Technician? "A nosiy can is empty".
                      Nobody is perfect..
                      • sharpmind
                        • Sep 2009
                        • 478
                        Even you say "NO OFFENCE" it still hurts a person who is trying to ask for help.
                        • kassa
                          • Oct 2008
                          • 79
                          @ Blank The best thing you can do is keep quiet. I say no more.
                          Thanks to everyone else for the answers that you gave me.
                          I will do the tests and will let you know.
                          • vargue
                            • Oct 2011
                            • 404
                            don't be sad my friend
                            peace on our guies first i would thank every technician sharp mind and zed and all poeple who shares ideas for help us and copiers community specialy ricoh community i would say to our friend don't be sad if some one attempt to trip our progress stay away out we all learn machine is hall knowlege never stop good luck guies
                            • kassa
                              • Oct 2008
                              • 79
                              I have replaced the clutches of the feed roller and vertical transport but the problem is not solved whereas the customer called me back.
                              Bye bye.
