SR5000 corner staple problem
  • Hemlock
    • 432
    Have a C900 that won't jog properly when corner stapling. Same finisher is on a 1357 and 1107 (in the same room), with no issues. Came up with a field fix - would love to hear any feedback (including whether I missed something obvious that would've fixed this). Should be a pdf attached.
    “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
  • Herrmann
    • Jan 2006
    • 792
    Re: SR5000 corner staple problem
    Investigate the joggers itself (Pos.: 16 & 18), they tend to get incisions from the Paper, if they are deep enough, they work like pincers then and randomly pull sheets out of alignment
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • Hemlock
      • 432
      Thanks; just checked - smooth metal.
      • Herrmann
        • Jan 2006
        • 792
        okay, i mismatched the sorter types, so it seems..
        I assume, that you already interchanged the sorters, so that we can be sure, that the problem is only this sorter?
        • Hemlock
          • 432
          Very good suggestion but, as these have plockmatic finishers attached, the disruption for the customer makes this impractical. If this field fix doesn't hold up long term, I'll definitely go that route.
