Black stripes-Ricoh CL7000
  • Jeff654
    I am getting stripes on most sheets. The quality if fine other than that. It started doing it 1 out of 10, now it's about 8 out of 10. Attached is a scan of a 8.5x11 sheet that should have been blank.
    Thanks for your help,
    Jeff
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    black bands
    Jeff,
    whats the black pcu life counter saying?
    Incontinentia Buttocks
    • bonnie750
      • 302
      Hi
      If the lines are in the subscan direction and only black it'll probably be the charge roller. clean with wd40. the pcu is easily stripped far enough to do this.
      It may also be caused by a damaged/worn drum cleaning blade
