hi to all,
its with my aficio 450. i already cleaned the waste toner case including the sensor in the transfer unit but a message "waste toner case is nearly full" appears
and after a few hundred copies "waste toner case is full appears" even though the waste toner case is empty.
i had to memory clear it 5801 to make it disappear but after 5801 "waste toner case is nearly full" still appears.
i tried replacing the whole transfer unit but it's still the same.
please help. thank you
