Re: strange waste toner case is full
hi,
i already did clean the sensors and even replaced the whole transfer unit including the door and connectors and even replaced the io but the message still appeared. since my client needed to use the machine urgently, for me memory clear was my last resort at that time for it to function since i didn't how to solve it.
anyway, after i replaced the bicu the message was gone so i guess the problem is not with the sensor, contacts or connector.
but i still need to fix the replaced bicu. if turning it off is not the solution then what is the solution?
thank you.
hi,
thank you.
