Hello,
I am getting this line ( black) on all colors running in the feed direction all the way through the page even through the void areas, when I start a job the line does not occur until about three to ten copies. I thought it might be the black drum unit but I'm still getting the line, when I replaced the drum unit the charge roller assembly was damaged so I had to use the old charge assembly. I cannot see it on the transfer unit and the fixing assembly looks good. The line looks choppy on the page kind of like small dots and dashes could there possibly be something on the laser slit glass, I cleaned it with the wand but no change. When I run the machine with single colors it does it on all colors. Thanks
