[ Firmware updating issue ] SC792
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    When updating be sure to cross reference the firmware part numbers on the screen before proceeding.
    As an example
    OLD: D0875572C NEW: D0875572D <-- OK to proceed
    OLD: A1234567 NEW: D0875572D <-- Do not update
    Due to supply issues in Japan some PCB boards may be supplied from alternative vendors.
    The function of these PCB boards remain unchanged accept they are preloaded with different firmware in order to operate correctly.
    A PCB board that has the wrong firmware loaded will NOT be recoverable and would need to be replaced.
    SC792
    The machine does not recognize the finisher, but recognizes the bridge unit.
  • Jomama46
    • 2900
    Re: [ Firmware updating issue ] SC798
    Thanks for the heads up Cipher, I didnt know it was possible to overwrite firmware with a different part number.
    sigpic
    A+; Network +; PDI+
    • Cipher
      • May 2006
      • 1309
      Re: [ Firmware updating issue ] SC792
      Nor me till I nuked a finisher last week lol.
      I knew it didn't look quite right but I said to myself... meh it wouldn't show up if it wasn't a valid update (right?)
      Guess the machine cannot tell the difference between a finisher with older type of PCB and the newer type of PCB.
      • Eric1968
        • 2458
        Had this with an MP6500/SR841 Finisher. During the update the machine freezed. I realized that the wrong finisher firmware was on the SD-card. When I switched off/on the machine kept asking for the SD-card. After a phone call with Ricoh Support I could recover by using 143 + 3x Clear.
        • Cipher
          • May 2006
          • 1309
          This is a different issue Eric (Ricoh have a newly issued RTB on it).
          What you have described is one of the procedures for recovering from Exx update errors.
          No this one will successfully update and you will think all has gone well.
          It's when you power off then back on that you are greeted with SC792 and a dead finisher.
          • Eric1968
            • 2458
            Thanks for the explanantion.
            • BLADE
              former propeller tester
              • 478
              yor not the first, a post 3 weeks ago FIRMWARE WENT WRONG, good info this thread tho
              • jonezy999
                just one copy??
                • Feb 2010
                • 952
                Looks like we are up for a new PCB.
                I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                • jonezy999
                  just one copy??
                  • Feb 2010
                  • 952
                  Does anybody know if a tech bulletin has been released in Australia for this problem yet? I've been searching the Ricoh site with no luck, also going back through my email archives just in case I missed it.
                  • BLADE
                    • 478
                    patience jonezy
                    • jonezy999
                      just one copy??
                      • Feb 2010
                      • 952
                      Originally posted by BLADE
                      patience jonezy
                      Patience? Never heard of it!!!How's this for a yarn, was reading this thread this morning thinking "I better keep an eye out for this." Left the workshop for the day and returned to find an MPC5501A with SR3020 configured. Was working when tech ran-up fine, upgraded firmware, finisher SC792. Murphey's Law? End of the day, I guess its the finisher PCB we need to replace, can someone confirm?Cheers.J.
                      • Choro1dal
                        • Jun 2008
                        • 176
                        Bulletins for the following models are available on TESSA:
                        Aficio MP 201SPF RD115016a
                        Aficio SP 3400N RM016016
                        Aficio SP 3400SF RM016016
                        Aficio SP 3410DN RM016016
                        Aficio SP 3410SF RM016016
                        Aficio SP 4210N RM001019
                        Aficio SP 4310N RM080016
                        Aficio SP 6330N RM047014
                        SR3020 RB804007
                        SR3030 RB804007
                        • BLADE
                          • 478
                          so thats 2 now , lordy! lol. good yarn, howz this one. Our run up guy was dealing with this issue exact same time you posted your thread - made us all feel better. You will need to replace the board(s). I havnt looked for the bulletin, if you cant find it try enter the fault in Knowledge base see if its there (previous post has some details also). have a good one
                          • Cipher
                            • May 2006
                            • 1309
                            Yup.
                            I've attached the released RTB on the problem.
                            • xerotec
                              • Oct 2009
                              • 45
                              I have similar problem with my mp6500 can anybody please send me latest firmware.
                              xerotec@yahoo.com
