When updating be sure to cross reference the firmware part numbers on the screen before proceeding.
As an example
OLD: D0875572C NEW: D0875572D <-- OK to proceed
OLD: A1234567 NEW: D0875572D <-- Do not update
Due to supply issues in Japan some PCB boards may be supplied from alternative vendors.
The function of these PCB boards remain unchanged accept they are preloaded with different firmware in order to operate correctly.
A PCB board that has the wrong firmware loaded will NOT be recoverable and would need to be replaced.
As an example
SC792
The machine does not recognize the finisher, but recognizes the bridge unit.
