MPC 4500 Print out toner not stick on the paper .
  • Copyjaya
    • Oct 2011
    • 59
    MPC 4500 Print out full colour toner not stick on the paper .
    If just print out normal wording its fine .
    i've change the fuser belt but still the same ..
  • Copyjaya
    • Oct 2011
    • 59
    Re: MPC 4500 Print out toner not stick on the paper .
    Please help .. dont know whether heather lamp not enough hot or other issues ?
    • xordi69
      • Jun 2010
      • 200
      use original toner?
      • Copyjaya
        • Oct 2011
        • 59
        Good question ..
        Need to double confirm on that as we used two type of toner ori & not ori..
        • xordi69
          • Jun 2010
          • 200
          whith original toner no trouble. Put original toner, exhaust not original toner in dev unit(make single color copies), and fix ok. Ive had the same problem whith not original toner.
          • leo34staffs
            copierman
            • Aug 2007
            • 503
            Are the fuser arms damaged? they put the pressure between the fuser rollers, is the paper type any different than normal? if so then the correct paper type will need to be set up. i.e. thick 1 etc.
            Networking skills are advantageous but use of a 3m vacuum cleaner is essential
            • Copyjaya
              • Oct 2011
              • 59
              will try setting the paper thickness next week..
              • Max
                • Oct 2011
                • 561
                Will be heat roller spongie orange one. Set the trays to thick 1 2 or 3 if using 80 gsm or heavier.
