weird machine
  • vargue
    • Oct 2011
    • 404
    weird machine
    machine didn't make rotat sort model 3025 i'm adding also consol but i'm noticed some thing weird this consol watched in touch screen but when i want to change paper measure machine from system setting didn't seen any consol did this machine need to update firmware???????????? and it distripute afew papers and stop. thanks
  • Eric1968
    • 2458
    Re: weird machine
    Originally posted by vargue
    machine didn't make rotat sort model 3025 i'm adding also consol but i'm noticed some thing weird this consol watched in touch screen but when i want to change paper measure machine didn't seen any consol did this machine need to update firmware???????????? and it distripute afew papers and stop. thanks
    I'd like to help but I really don't understand your post. You have a problem with rotate sort?
    • vargue
      • Oct 2011
      • 404
      Re: weird machine
      rotate sort working afew papers then machine sluggish or hangged
      • Eric1968
        • 2458
        Re: weird machine
        Do you get any error messages or SC's?
        • vargue
          • Oct 2011
          • 404
          Re: weird machine
          sc 870-1 but i used to rotate without hdd
          • Ricoh-ono
            • 338
            Re: weird machine
            Firmware history shows that several problems were addressed when using rotate & sort. I would definitely bring the machine up to the latest firmware.
            Do what you can, with what you have, where you are. ~Theodore Roosevelt
            • sharpmind
              • Sep 2009
              • 478
              Re: weird machine
              You have to replace the HDD first.If you are sorting a lot of copies, HDD is required.Some functions in the machine are disabled when HDD is defective.
              • vargue
                • Oct 2011
                • 404
                Re: weird machine
                when i faced this threat i went to anther customer and also didn't have HDD and working perfect so guies thanks for help i will try to update firmware.....
