hi to all,
1) aficio 1045.... can i use alcohol or water to clean the charge roller? also to remove the thin lines in the copy caused by the charge roller?
if not, what can i use to clean the charge roller?
2) aficio 551.... can i put a little silicon oil or grease inside a bushing in the drum unit?
thank you...
thank you...
