ricoh mpc6501sp problem of sensor
  • tulipano
    • May 2010
    • 124
    I have aprejudiceinfotecmpc6501spgives meproblemssensori.dalfirst andsecond drawerdoes not recognizethe paper whilethe thirdis jammed.
    salve ho una infotec mpc6501sp, mi da problemi si sensori.dal primo e secondo cassetto non riconosce la carta mentre dal terzo si inceppa.
  • Jomama46
    • 2900
    Re: ricoh mpc6501sp problem of sensor
    Wow, you do have problems.
    replace the sensor, update the firmware.
    sigpic
    A+; Network +; PDI+
    • rthonpm
      • Aug 2007
      • 2859
      Check and make sure there isn't paper jammed into the back of the trays. Often users will clear a jam and leave paper back there which can block the tray sensors. Sounds like firmware may be a good step to go too.
