Ricoh FT3713
  • copyman
    Owner / Technician
    • Sep 2005
    • 4709
    Ricoh FT3713
    Customer uses this in their warehouse. They make a few copies a day. Copies were dark so I replace the drum blade and developer. Strange thing happen when doing the developer calibration. I went into SP mode #65 and started calibration. It started running with scanner moving back and forth. Went to wash my hands and when I came back machine had stopped and 22 was on display, machine was locked up. Not sure if this is an error code, is there suppose to be an "E" with the code #? There was no "E" just "22". Only have the intravia guide and 22 is scanner error, if it is an error. I moved scanner by hand and when powered on it returned to home pos. I tried resetting the code with SP 97, etc but didn't work. I left with machine locked up and 22 on display. Thanks for any help with this old dog.
  • sandmanmac
    • 3981
    Re: Ricoh FT3713
    Sorry, I don't have any advice for you, but I did have a PDF of the SM on hand. Here's the 2 pages referring to Code #22. Hopefully it helps:
    FT3713 - Code 22.pdf
    • copyman
      Owner / Technician
      • Sep 2005
      • 4709
      Re: Ricoh FT3713
      thanks sandman. The only thing I don't get is why there is no "E" alternating if that is an error 22 code. It has been a long time since I serviced this old model but I thought it had an "E" when machine throws a code?
      • sandmanmac
        • 3981
        Re: Ricoh FT3713
        Oh, I see - just a solid '22' then, and not flashing? That's definitely a strange one. I never experienced anything like that WAY back in "the day", and I don't see anything in the SM about it. Sorry
