Ricoh Aficio MP161
  • Matty54
    • Dec 2011
    • 15
    [CQ] Ricoh Aficio MP161
    Getting back ground on front side of copy and black bands on the back side(top). I replaced the photo conductor unit thinking that was the problem but it didn't fix the problem. The machine has 77,000 copies on it. HELP!!!
  • rthonpm
    • Aug 2007
    • 2847
    Re: Ricoh Aficio MP161
    Try cleaning or replacing the transfer roller, also are you using OEM or generic toner?
    • ucinn
      • Jun 2009
      • 383
      Check the cassette grounding tabs.. I believe there's a tech bulletin on it.
      • leo34staffs
        copierman
        • Aug 2007
        • 503
        Is the Id sensor plugged in? Or is it dirty? Try running id sensor analysis and check the readings. Also is the dev bias ok?
        Networking skills are advantageous but use of a 3m vacuum cleaner is essential
