Ricoh Aficio 2045 keeps asking for toner
  • Gunhed
    • Jun 2008
    • 12
    #31
    Did you end up finding what was wrong mrwho? I have the same problem but with copies going light as well, gonna try a few of the suggestions here.
    • allan
      RTFM!!
      • 5462
      #32
      Check gears on development unit if the augers dont turn no toner gets to the TD sensor
      Whatever
      • Gunhed
        • Jun 2008
        • 12
        #33
        Yes.. after changing the developer, TD and ID sensors plus a hopper seal I have discovered the dev unit was pushing out ever so slightly maybe 3mm and causing the dev mixing auger not to turn. Thing that threw me was the mag roller itself seemed to be turning so I assumed the mixing auger was as well. I'm thinking maybe the TD sensor connector would of had a poor connection if any at all because of this, may of been the source of the 'replace toner' messages.
        The dev locking bracket is in its correct position but the dev tank still moves out more compared to another machine I looked at, made a modification and all is going good so far.
        Thanks for all advice posted.
        • mrwho
          Major Asshole!
          • 4299
          #34
          Sorry for not replying sooner, but I missed this one until your most recent post.
          In my situation the machine keeps asking for toner but the copy comes out fine. It's been like this for a month now, though, so I just told the customer "let's see what develops" (no pun intended).
          I'm just waiting for either the machine blowing up or a solution comes up for this problem.
          Mascan42
          Ibid
          • apollo
            • Mar 2008
            • 191
            #35
            Hi Guys,
            Had same toner problem and discovers the auger gears in dev unit were worn n not turning toner feed mechanism but mat roller was turning causing toner not to feed in.
            Replaced gears, and worked like a treat.
            hope this info helps
