Aficio 2035 sc 353
  • Ronan
    • Aug 2011
    • 55
    Aficio 2035 sc 353
    Hello, I have a problem with a machine that runs the code SC 353, and clean the ID sensor and put a new developer and continues with the same, any ideas? regards
  • JustManuals
    • Jan 2006
    • 9838
    Re: Aficio 2035 sc 353
    Paul@justmanuals.com
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1254
      When you say new developer , do you mean the whole developer unit or just the powder. If you just replaced the powder......check gears on dv unit. Could be worn. What's the meter on that copier?
      • cleardata
        • Jul 2011
        • 137
        • Ronan
          • Aug 2011
          • 55
          Change the units to another machine and there was no problem, I think it is in the sensor or the main board. I'll keep trying and will let you know. thank for the tips
          • blazebusiness
            • 1254
            Goose Guide on that model lists 4 fixes for that code:
            ID sensor current error - poor or no drum ground
            ID sensor current error - clean and reinitialize ID sensor with SP3-001-2
            ID sensor current error - replace ID sensor
            ID sensor current error - replace IOB
            • Ronan
              • Aug 2011
              • 55
              I fix it. sensor was broken. change it and it worked. thanks
