I have a problem with ricoh mp 2075 toner
  • tulipano
    • May 2010
    • 124
    I have aproblemwithricohmp2075toner.the bottle oftonerrunsoutand thencopieschiare.ildrumand developerarein thethicknuovi.invece2207*ForcedTonerSupply,turnthe bottleof toner(and'ok).
    ho una ricoh mp 2075 da problema di toner. la bottiglia di toner non gira e quindi le copie escono chiare.il drum e il developer sono nuovi.invece nella sp 2207* Forced Toner Supply, la bottiglia di toner gira (e' ok).
  • Eric1968
    • 2458
    Re: I have a problem with ricoh mp 2075 toner
    I have really no idea what you mean...
    • rodrigo pevidor
      • Oct 2011
      • 11
      do Hou mean?
      did you mean, when the toner ends you can do it works with sp 2207? if yes, you probably have a problem with the part supply toner unit, you must change it, or grow up the little holes where toner pass trough for. if I'd understand you, your machine bring toner from bottle to supply unit, but don't to developer unit, then the toner accumulated in supply don't turn on the end toner sensor, doing the lack of toner and light copies or ask for toner. is it true? sorry for my english, and could try explain more minutely the problem and your actions to solve it. I m waiting your answer, bye
        • 23009
        • Jomama46
          • 2900
          Replace the toner supply clutch (on the developer drive motor board)
          sigpic
          A+; Network +; PDI+
