Scanning from Ricoh 1515 mfp to windows xp folder
  • Shayx
    • Nov 2011
    • 32
    hello, i know its a network printer
    but i currently have it connected to a computer via USB cable.
    i want to know how to scan from windows scanning wizard. it detects my HP officejet 4500
    but it doesn't detect the Ricoh 1515 as a scanner.
    what can i do? i've searched for scan driver and can't find one.
    I DO NOT have the option to connect it to network so please help me to scan from windows scanning wizard.
    thank you.
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Scanning from Ricoh 1515 mfp to windows xp folder
    this machine can scan on network twain only. tried it on usb but can't let it work.
    Nobody is perfect..
    • Shayx
      • Nov 2011
      • 32
      wow that's really disappointing. this is such a basic feature.
      I've heard a tip from a friend that said that maybe i can connect the printer with a LAN cable
      directly to the PC.
      can you assist me how to do it if it's possible?
      thanks.
      • rthonpm
        • Aug 2007
        • 2859
        Scan to folder will not work on the 1515 without a middleware programme called ScanRouter, which is no longer supported by Ricoh. The easiest scanning method on this model is scan to email as network TWAIN is often blocked by firewalls and ScanRouter always introduced its own headaches.
        When this machine was developed Ricoh hadn't started using their current Unix-based embedded OS, which gave the machines Samba for direct access to share folders.
        • rsyarcia
          • 711
          directly to the PC.
          thanks.
          use a cat5/6 crossed cable, then on the lan, you should make the ip addresses of the devices(pc/mfp) static.
          Nobody is perfect..
          • Shayx
            • Nov 2011
            • 32
            you say scanrouter is no longer supported by Ricoh but
            i can download the program from their site.
            so can i get it to work?
            and what version do i need to download?
            • copyaction
              • Oct 2007
              • 991
              Check this thread for the download:
              http://www.copytechnet.com/forums/ri...-download.html
              • Shayx
                • Nov 2011
                • 32
                this is so complicated...
                i've downloaded the scanrouter v2 lite program, installed it.
                now i can run the scanrouter admin utiliy
                but how do i get starting with scanning to my computer via USB?
                • rthonpm
                  • Aug 2007
                  • 2859
                  Ricoh MFPs do not support scan via USB as they use Samba as their default transmission method: only network scanning is supported. Keep in mind these machines are designed with the intent of being used by multiple users and not as a personal device.
                  • DiskCopy
                    • May 2011
                    • 33
                    Another alternative is Scan-to-E-mail if it fits in you necessities.
