firmware
  • COPYMAC
    • Feb 2011
    • 13
    [Error Code] firmware
    Hola, sera posible conseguir firmware para la linea ricoh.
    atte daniel
  • mikadonovan
    • May 2008
    • 2931
    Re: firmware
    This is an English language forum. You need to use a translator like Google if you want some replies.
    NEVER ASSUME ANYTHING
    • Eric1968
      • 2458
      • zhong
        Re: firmware
        I want! ThankS!
        SD Scanner (Scanner) B8405560 Ver.b3_2.19 or later
        SD Printer (Printer) B8405523 Ver.5.21 or later
        Network DocBox (NetFile) NFA B8405580 Ver.1.00 or later
        Web Support (WebSys) B8405570 Ver.1.21 or later
        WebUApl (WebUApl) B8405590 Ver.2.02 or later
        System/Copy (System) D1015541 Ver.5.20.2 or later
        Network Support (NCS) D1015542 Ver.5.73 or later
        Animation D1015544 Ver.1.06 or later
        Engine (Engine) D1015223 Ver.5.19:20 or later
        Language Install (Language) B2345329 D Ver.2.01 or later
        OpePanel.EXP(LCDC)[NA] B2345321 C Ver.2.01 or later
        Option PS3 (PS) B6135130 Ver.1.00 or later
        • Eric1968
          • 2458
          Re: firmware
          Originally posted by zhong
          I want! ThankS!
          Sure, shall I also send you the whole machine and finisher with it for free?
          • TonerMunkeh
            Professional Moron
            • 3865
            Re: firmware
            I want! ThankS!
            You want?
            How about "ask nicely" or the response will most likely be "fuck you!".
            Hit it.
            • zhong
              Re: firmware
              ThankS!
              my E-mail:zhongzhong51@yahoo.com
              ThankS!
              • mrwho
                Major Asshole!
                • 4299
                Re: firmware
                I believe the "I want" part was due to his weak grasp on the english language and not due to some kind of "I believe I deserve it" syndrome.
                Nevertheless, good luck getting firmware on a first-post basis.
                Mascan42
                Ibid
                • teebee1234
                  • Jul 2008
                  • 1670
                  Re: firmware
                  Looking at your biography I'm going to say you are not from the US (or Australia). I will take a wild guess and say you are from China and probably have some difficulty with the language. In any case, asking for all of the firmware for a particular model is a bit much. This is not something that can be emailed as an attachment, someone will have to take the time to upload it to a file share site. You need to find a reliable local source or contact an authorized dealer for help. Your biography says you are trained on Ricoh and Canons so you should have access to the Ricoh Support site or need to register there.
                  Basic Information
                  Date of Birth: January 20, 1984 (27)
                  About zhong
                  Real Name:
                  zhong
                  Country: United States
                  State/County :au queensland
                  Where are you from (City, State): united states
                  Biography:canon ricoh
                  Interests:canon ricoh
                  What Year Did You Start in this Industry:2000
                  Most Hated Brand:canon ricoh
                  What was the first machine you worked on:canon ricoh
                  Last machine you were formally trained on:canon ricoh xerox
                  Gender:Male
                    • 23010
                    Free Translation and Professional Translation Services from SDL
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      Re: firmware
                      Basic Information
                      About zhong
                      Real Name:
                      zhong
                      Gender:Male
                      Has my state been annexed by the U.S.?
                      Did I miss something?
                      I KNEW sleeping through that alarm would lead to no good
                      • Lagonda
                        • Aug 2008
                        • 1649
                        Re: firmware
                        Its been happening for a while now Oze, first Coca Cola then McDonalds, we did try to buy them off by sending Paul Hogan overthere as a peace offering but it hasn't seemed to have worked.
                        • mrwho
                          Major Asshole!
                          • 4299
                          Re: firmware
                          I somehow don't believe him to be either Brazilian or Portuguese...
                          Mascan42
                          Ibid
                          • teebee1234
                            • Jul 2008
                            • 1670
                            Re: firmware
                            Sorry Blackcat, I was referring to the 2nd poster requesting firmware, not the OP.
