I have a weird issue that I've tried to work through. This aficio 2027 keeps jamming right at the fuser, like the paper can't be fed into the fuser. It folder the paper almost in half and jams. It will do this 3 times, and then after the 3rd jam, it will feed and print/copy with no issues until the machine has set idle for about 30 to 60 minutes. After that time frame, it will continue to jam 3 times and then print/copy with no issues. And the process repeats.
I have checked and replaced the paper feed rollers, I am tight on $$$ so I have not replaced the fuser, however I have replaced the rollers and bearings in the fuser.
I'm really at a loss here and hopefully someone will have some advice to lend.
Thanks,
Pat
Thanks,
Pat
